read more .txt tab delimited files
I built a labview file (view attach) to read and visualize measures from photovoltaic panel. This file allows me to read a .txt tab delimited with climatic measures or electrical measures, and visualize possible correlations through graphics. There is a way to read two .txt tab delimited files, one with electrical measures and one with climatic measures, in the same dialog box? Because i need to see correlations between electric and climatic data. Until now I didn't find any solutions,
Poisson
(2,784 Views)
Hi Poisson
I haven't understood very well your question.
You have already developed the LabVIEW code to read a tab delimited text file; now, why don't you reuse the same code to read a second txt file??There is no way to set a File Dialog Box to read two file paths. Anyway, even if you acquire two file paths (by means of a cluster of File Dialog Box control for example) then you have to process them one at a time because the Read Spreadsheet File function open a reference to a single file at a time.
In other words, why don't you include the code after the Read Spreadsheet File function in a subVI; in this way you can set two reading chains that work together.....
Best!! Cat Happy
(2,739 Views)
Hi bronzacuerta (your nickname suggest me that you are italian, it's possible?...in tal caso ciao!)
I think that i've understood your approach that in effect is linear and logic but i'm totally new with "labview modus operandi" so i'm sorry if i said somenthing wrong. So if i use the same code after Read Spreadsheet File function in two subVI,then i can visualize climatic and electric data in front panel and combining them in graphics?
Thank you,
Poisson
(2,716 Views)
Ok le discussioni del tuo profilo mi confermano che sei italiano Smiley Very Happy
(2,714 Views)
If you have to files with a known naming relation (say they are   day1_electrical.txt and day1_climate.txt) then you could use the file path from the first load to programatically create the file path for a second one.  This, unfortunately, requires strict naming conventions for your files.
(2,703 Views)
