read multiple tdms files
Two questions:
1) how can i rename the different signals in the tdms file? Now they are names "untitled x". I am looking for an elegant solution, because i record about 200 different Signals.
2) Is there an "easy way"  to select, read and concatenate multiple TDMS files to show them in a graph?
(3,363 Views)
Unfortunately, no.
In the past I wrote a small program that read the channels out of the old file one at a time and resaved it into a new file with the new name.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,344 Views)
I had a similar goal with grouping plots and  rearranging them on the X-axis, so I put together this pretty quickly to search a range of TDMS files for a specific channel, should be able to adapt it pretty easy to suit your needs, once you manage to rename your channels.
(3,336 Views)
