read specific entries from spreadsheet
Heres the prob: I have tab delimited files. Basically there are 4 columns: 1st is time, 2nd is Xaxis accel, 3rd is Yaxis accel and so on. The whole file can go up to 120 odd seconds @ 10000Hz, i want to graph the whole thing so I can do analysis on the whole file. But the problem is, it is divided into sections of 2000 samples, ie 0.2 seconds. every 0.2 seconds there is a set of headings:
Channels 3
Samples 2000 2000 2000
Date 2006/09/11 2006/09/11 2006/09/11
Time 11:44:24.405999 11:44:24.405999 11:44:24.405999
Y_Unit_Label g g g
X_Dimension Time Time Time
X0 7.9999999999999993E-1 7.9999999999999993E-1 7.9999999999999993E-1
Delta_X 0.000100 0.000100 0.000100
***End_of_Header***
X_Value Acceleration0 Acceleration2 Acceleration3 Comment
It is possible to go into notepad and manually delete the headings and use read from spreadsheet file.vi but there has to be a better way as doing so is so tedious? I tried using delete from array but I need to some how loop which rows i want deleted.
Attached is my VI:
(3,616 Views)
Many ways to solve this problem, here is just a quick and dirty way:
All readings will give you a 0 in several columns when you parse a header string as spreadsheet. So just get rid of all rows where column n is 0.
If you have time and are going deeper into LabVIEW, get the OpenG-stuff, there is some VIs that might help you.  But coding it on your ownwould propably take less effot for now.
Felix
(3,612 Views)
Do the headings have any regular pattern?
If so, you can iterate through each row, using a for loop.
If row == regular pattern, do nothing.
If row != regular pattern, add to data array.
Cory K
(3,607 Views)
