read specified values from table
Hi.
I create a VI to read some of the values from Text File.
However, I would like to read only certain values of it only.
Please refer to the Front Panel of attachment.
For Angle table, I would like to have only values from -90.79 until 88.21 which means from no 33 until 212. It is the same the table for Pcyl 1.
Anyone could assist.
Thanks.
- Beginner -
(2,805 Views)
Hi Fird,
i can't open your vi at the moment, but i think you can use the "Read From Spreadsheet File" function to get an array of your values. Later you can analyze your data and present only the range you need.
Hope it helps.
Mike
(2,800 Views)
