read stacked tiff images generated by ImageJ
Does anyone know how to use IMAQ ReadFile to read the stacked tiff file generated by ImageJ(as attached, 4 images in the stack)?
It seems possible but IMAQ ReadFile somehow only gives the first image of the stack file.
Message Edited by ein on 04-07-2010 03:09 PM
(4,684 Views)
It isn't possible.  IMAQ ReadFile can only read the first.  You'll have to make ImageJ split up the images into individual files.
Randall Pursley
(4,663 Views)
Hi Ein,
Randall is right.Unfortunately while .tif files are supported, multiple paged .TIF files are not supported by IMAQ Vision. If you must use this file format, I believe that there are many freeware or shareware programs that can allow you to split this file type into individual pictures. I apologize for any inconvenience.
Esmail Hamdan | Applications Engineering | National Instruments
(4,646 Views)
Easiest way is to write a wrapper around libTIFF.  One person has done that here: http://forums.ni.com/ni/board/message?board.id=170&message.id=417600
(4,635 Views)
