read strings from array for loop
@saintalan94 wrote:
Hi Ranjeet,
It's in my attachment eee.jpg where the G!@#$%ibberish XML is the source of string and I will need all the values in the '<val>'s... and </val>'s... But now my program could only get me one of the values.
Alan
Can you post the VI(With 'G!@#$%ibberish' as default) becasue from image file I cant copy the string. And dont tell me write the values Smiley Very Happy Just kidding.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 12
(640 Views)
You should improve the design of your code, attached vi's produce what you want as the output. I believe your design could be made much more flexible and smaller if you take these vi's and create case structure inside it for each data type.
Good luck.
-DP
BatchTest Corp.
NI Alliance Partner
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
Message 12 of 12
(635 Views)
