read tdms repeatedly
please tell me why is the VI incorrect and how to correct it. I want to read the same tdms file repeatedly ,  thank you!
(2,443 Views)
What is it doing that seems to be incorrect?
From what I can see, you have the loop iteration value wired to the count input of the TDMS read.  That means on the first iteration i=0, you will read zero items.  Next i=1, you'll read one.  next i=2 you'll read two.  i=3, you'll read three.  So every loop iteration, you'll be reading progressively larger chunks of the file.
You should just have a 1 wired to the count terminal.
(2,416 Views)
