read the 10Khz - 250mb data using diadem
hi,
        i am using labview, i have to do data logging with 10kHz sampling at event task, that file processed by TDM file format, that will be generated one file per day. nearly i will get 250 mb of file size, my question is it possible to read all the data from diadem....?
tell me how many points can be read at a time....?
need some documentation about diadem, that will be really help full to me
Balaji DP
(2,434 Views)
Accepted by topic author Balaji_DP
You keep doing that...
Have you done a Google search on 'Diadem maximum data' ?
That's what it comes back.
http://forums.ni.com/ni/board/message?board.id=60&thread.id=10574
Try first... and if you stuck then ask.
(2,424 Views)
