read time increment in TDM
Hello
I save data in LV 7.1 to TDM and open them again. In the channel properties, many are there, including time stamp t0, but waveform increment is read back as 0.0. When I look at the channel props in DIAdem 9.1 it shows the correct value.
How can that be?
Thank you for sharing your insight.
Michael
(2,921 Views)
Hi Michael,
is your LabVIEW indicator for the waveform increment maximized and you should have a look on the data format.
Best regards
Rüdiger
(2,893 Views)
