read/write remote files (Datasocket)
Hello all,
I need to be able to read from, and modify text files on a remote computer. More specifically, a client application needs to access/change the files on a server application (with a nasty firewall in the way). I have read up on the info on using data socket, and am a little confused.
The server PC (which I suppose would be running the datasocket server), is connected via LAN to a server/firewall (the firewall has an IP address a.b.c.d for example).
How do I use the datasocket read command (from the client computer outside the local network), as the file(s) I need to access are not actually local to the server/firewall (ie not running on a.b.c.d). So I dont suppose using something like
file:\\machine\mydata\readme
.txt[text] would work?
Sorry for the rather vague question... does anyone have any advice on how to modify files remotely?
Thanks for your help
Neil
(2,827 Views)
sorry for the late post but I just seen your question. Try this and see if it works.use dstp://your address.
You will also have to have the server configured to allow access to the machine.I do not know if datasocket will allow you to access a file on another machine but try this and see if it will work.
Sorry i could not help more
Joe
Joe.
"NOTHING IS EVER EASY"
(2,827 Views)
