reading 3 voltage at the same time using the NI DAC 6008
Hi
i have a problem here ,i would like to read 3 differents voltage with my DAC USB 6008 and that seem to be not working  .can some one help me by telling me what stucture i should use?
(3,053 Views)
You just have to specify all channels in a single task. Don't use three different DAQ Assistants or three different DAQmx Reads off using the lower level functions.
(3,039 Views)
thank you Dennis
do i have to use the same dac assistant even if i want to read 3 differents voltages at 3 differents points of my circuit?
(3,033 Views)
Yes, of course. You had instructions on how to do this when you created it. Once created, you just click on Add when you open the assistant.
(3,030 Views)
