reading Excel sheet
How to read data from excel sheet
i want to read the corresponding value of another column if i enter
the value of another column.
suppose i am entring the value for column 1 and row 1 then i want to
retrive all values in that row
(3,196 Views)
this one i "simple ActiveX"-programming. There are some examples supplied with LV for programming ActiveX, even with Excel. So maybe you should look into the examplefinder and search for excel.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,185 Views)
Duplicate post.
You should try the Excel board.
(3,175 Views)
