reading R32 files with diadem connectivity
Hi!
I have a bunch of Diadem R32 files and I need to read them in labview, hence I installed labview diadem connectivity VIs in order to read them. It looks like that this tool can only read R64 files. If this is the case how should I approache this problem. I don't have Diadem installed.
(3,482 Views)
Hi there,
My name is Scott, I'm an Applications Engineer here at NI.
I wondered whether you had managed to solve this issue? Or are you still working on this?
I look forward to hearing from you.
Scott
(3,341 Views)
Hi scott!
Unfortunatly I didn't solved it using LV. I wrote a script in Matlab instead. In principle one can do the same thing with LV (I think) using string functions but that would have taken much more time (for a newbi like me) to do. If I have time to do that I'll let you now how it went.
Best regards
(3,333 Views)
