reading an activex spreadsheet
Post your solution. I'm curious. It is hard to mess with the activex controls because most of the properties aren't documented very well.
Message 11 of 12
(485 Views)
I just had to change the "Visible Range" property to "Used Range."
However, for some reason it seems that the minimum number of columns it will report is 5...doesn't matter if I have one column, or 5.  If you add more columns, it counts them correctly.  And I just checked on the number of rows...minimum that it will report is one.
Better than nothing, but if someone knows how to change that little problem, please share.
Message 12 of 12
(480 Views)
