reading channel headers
Hi, I have a file in the following format:
Ch1_NAME
Shot number
number of samples
time         data
time         data
time         data
time         data
Ch_2NAME
Shot number
number of samples
...etc
An example of which is attached. I want a VI that creates an array of data, time, channel names and shot numbers. I can do all apart from the channel names part. There doesn't seem to be an easy way to create an array of strings in the same loop as array of numbers. Is there a funcion that allows the reading of strings and floats? I have attached my VI, I wonder if anyone knows an easier way to read this type of file?
Message 1 of 10
(4,277 Views)
Hi phuech,
I would do as follows:
1) read in 3 lines of text
2) parse those 3 lines to get name, shot, #samples (using "scan from string" with format string "%s %d %d")
3) read in #samples lines of text and convert to time/data array(s)
4) start again with 1) until EOF
Message 2 of 10
(4,270 Views)
Thanks very much for your reply. 'Read lines from text file' outputs an array of strings. Do I need a seperate function to change this into one string? As scan from string won't accept an array.
Message 3 of 10
(4,259 Views)
Hi phuech,
interesting - at the moment I only get a long string... You should note which LabView version you are using!
Anyway: use 'concatenate string' to convert an array of strings to one string.
Message 4 of 10
(4,257 Views)
Very sorry. Labview 8.2.1 Full development system. Is there any chance you could put up a quick example VI so I can see how you read out the data. I can't get the read lines function to start a number of lines into the file, which is needed to read the data and time arrays, or indeed to read the next channel.
Message 5 of 10
(4,252 Views)
I got it work. I have attached my VI. I have a major concern that it appears to be a very slow method of achieving what I want. it takes around 2 seconds to read one channel. Multiply that by 32 and we have more than a minute to read a file! Maybe I haven't quite understood/made a mistake?
Phuech
Message 6 of 10
(4,241 Views)
Hi Phuech,
I changed your vi a little bit... Now it returns an array of cluster, each containing name of sample and sample data.
You made no (big) errors - but you didn't code according to speed Smiley Wink It's not a good idea to create new strings in every iteration.
It's better to use the scan offset instead or to read just the part of the file you need next...
Message 7 of 10
(4,235 Views)
Thank you very much for your help and patience. Your mod is almost perfect but it doesn't appear to output the time series data... Other than that, it reads much quicker. I can't imediately see why the time series is not coming out because your mod appears to have a similar form as "read spreadsheet file" which does output both.
I didn't really realise I was creating a string every itteration, but now I have yours for comarison it appears a much more elegant way of doing it.
Phuech
Message 8 of 10
(4,232 Views)
Hi Phuech,
it's hard to get 5 stars in this thread Smiley Wink
Well, yes there's an error in my last vi. Maybe the 'convert spreadsheet string' doesn't like your UNIX-style end-of-line character (just 0x0a instead of MS-DOS 0x0d0a)...
So I rewrote this part, it's not as elegant as before but now it works Smiley Happy
Message 9 of 10
(4,213 Views)
Thanks a lot. That works fine. You've been a great help. 5 stars.Smiley Happy
Thanks again
Phuech
Message 10 of 10
(4,204 Views)
