reading data flow files
I like to know if its posible to read dfd files, Dataflow files. I include an example of the file format.
Thanks in advance
B Bakels
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(4,352 Views)
Hi B Bakels,
you can read this files with the "Read From text File" or "Read from Binary File" function. What do you want to do with this data in LabView?
Mike
(4,349 Views)
Yes i know, but i would like to extract the data form the file but its encrypted in dataflow format..? Thats my problem
thanks in advance,
Promedes and DSM
(4,340 Views)
Hi Bart,
do you have some link to file format explanation? Just from that extension we cannot help...
(4,338 Views)
Its a fileformat form the firm kistler. I attached a file to the first post. I dont know if its possible to decrypt this file with labview
Promedes and DSM
(4,302 Views)
Hi bartb,
we saw your file, but i think the question from gerd is, if you now how to read this file. Do you know the meaning of each byte?
Mike
(4,299 Views)
Hi bartb,
well, we know that you attached an example.
But we don't know the file format!
We can only guess:
-First 0x1270 bytes contain header data (identifier, version numbers, date/time strings, information on used hardware, channels, etc.). You have to know the format to get it into human readable form.
-Remaining bytes (starting at offset 0x1270) seem to contain 16bit data (according to used PCM-DAS16 hardware?). The data seem saved in big endian order...
The attached vi will load the data part of the example file - you have to interpret the data as I neither know the format correctly nor do I have knowledge what those data represent...
Message Edited by GerdW on 07-10-2008 02:09 PM
(4,293 Views)
