reading data takes 2 seconds
Attached.
Thank you.
Islam means peace
Message 21 of 28
(1,592 Views)
You haven't changed The read delay. In FWB6010 Flux Query, right where I circled, you should have new delay constants. You should only be running this VI. Running your top level without fixing the subVI is just a waste of time.
Message 22 of 28
(1,584 Views)
It seems that when we exit the code, it retains these constants (1000milisceond). I should have changed the default values. I started the code and I changed these values and saved them without exiting the code or the sub-VIs and the time delay was there.
Thank you for your help
Islam means peace
Message 23 of 28
(1,581 Views)
Accepted by topic author Hadiq
Either change the VI I mentioned or change the front panel constants of the write and read functions.
Your debug may find out that the instrument requires a long delay.
Message 24 of 28
(1,576 Views)
I'll try this again on Monday.
Many thanks Dennis for your help.
Islam means peace
Message 25 of 28
(1,573 Views)
The instrument can make the mesurements in less than 300mSec.  Gosh, try to RTFM on the F. W. Bell website.
Sometimes it is not so easy to RTFM----- FWB could do better but, a STFW with "dedication" can show the info about FWB6010 speed of acquisition.
Message 26 of 28
(1,563 Views)
Hi Dennis,
It works!! As you suggested I changed the time delay in both FWB6110 and Kiethley to 500ms and 200ms. It seems that 500ms is better in terms of taking more points. 200ms is ok but the data points are about half of the data points when allowing more time delay.
Thank you very much indeed for your help.
Islam means peace
Message 27 of 28
(1,530 Views)
Hi Jeff,
Thank you for the points you made.
Islam means peace
Message 28 of 28
(1,529 Views)
