reading file and count and decimate array
Hi all
2 little questions:
1)in the count of a read file block how can I insert the EOF(end of file)
condition? instead of use (as now I'm doing) a fixed integer.
2)anyway the array that come up is a 1x480 and i want subdivide it in a
16x30 getting the i-th's 16 elements (the columns) for each of the 30 rows
I've used the decimate array function but unfortunately I have to know
exactly the number of rows that I want, is there a way to set the rows with
a variable number? (getted for example from a digital control)
Thank you very much to any of you that will dedicate me a little bit of his
time.
(3,243 Views)
I am not sure what you mean in question 1 but I can help with question two. What you will need to do is write an algorithm that will take a 1-d array and make it a 2-d array. Depending on how you want the data split, I supect you will need 2 nested for loops. The great thing about the 2-d array is that you can have n number of rows.
(3,243 Views)
If you want to read the entire file, use a very large integer and it
will only read what is in the file. Or you can use the more advanced
file I/O functions to seek and tell the file size and read that many bytes.
It sounds like you want to use the Re
size Array node. Grow it to have
two inputs and this will allow you to shape your 1D array to a 2D array
of nxm where you can set n and m at runtime. If you don't have enough
data in the 1D, they will be default, and if too much, it will be use
only what it needs.
Greg McKaskle
(3,243 Views)
