reading from MS Excel Spreadsheet
I am trying to convert an MS Excel Spreadsheet to a 2D array.  I was wondeing if there was a simpler way to do it other than using a lot of property nodes to activate each cell and 2 for loops to copy them.  The other problem I am having is that I want to select only certain columns and rows to be copied.
(2,778 Views)
This is a frequently asked question, and a search would have turned up the following: Using ActiveX to Copy an Excel Range to a LabVIEW Table
(2,772 Views)
