reading from spread sheet vi
Dear All,
I am trying to read this text file saved in ASCII but it does not load the data correctly, I saved this file in matlab using the command "save moonman y -ascii -double -tabs". then i used read from spread sheet.vi to open it, i want to see the data in waveform chart. I attached the waveform chart both with all rows and first row? and used double...can any one help.
thank you.
Message 1 of 8
(5,314 Views)
I think the attached will do what you want.  It reads in your file, decodes the tab delimited string, and plots in a waveform chart.
Paul
Message 2 of 8
(5,304 Views)
Dear Paul Schlagheck,
thank you for the wonderful program but in the waveform chart, the waveform that is saved shows up distrorted.
Could you maybe tell why this is ?
sincerely,
Munir.
Message 3 of 8
(5,283 Views)
Glad to try and help.  Distorted?  Could you please clarify that?
Paul
Message 4 of 8
(5,277 Views)
hi Paul, i have attached a screen shot, and also the file, the pic. shows how the waveform looks like.
thanks in advance.
Message 5 of 8
(5,253 Views)
Interesting... That is the same plot I got based on the file you posted me.  Not sure why you would not have gotten the same out of the box with my example.  Interesting.  did you modify the code I sent you?  I downloaded your file, and my example... and I have attached the result.
Paul
Message 6 of 8
(5,244 Views)
the problem is the decimal-character. If you change all the dots to commas in your text-file, it will work. Or you change the setting of your LabView Program under options -> frontpanel -> local decimal-character
Hope this helps,
                                    Magnus
Message 7 of 8
(5,234 Views)
Good catch... I do not deal with localization often.
Paul
Message 8 of 8
(5,222 Views)
