reading multi channels in DAQmx
I have LV2012 basic package and I am attempting to read multichannels from a PXIe-6361.
the code used is
DAQmx read vi . compiles fine(no broken arrow) but errors when run with an error message of: "multiple channels in data, USE the daqmx multiple channels read vi." where is this the multiple channel read vi ? or is that in a different package ?
(2,280 Views)
Hi Tony,
DAQmxRead is a polymorphic VI which has several "versions" hidden under it's surface. You have to select the correct reading mode by selecting the polymorphic instance: something like "N channels, N samples" should be ok...
(2,274 Views)
The VI DAQmx.vi is a polymorphic vi that have a selection Analog 1D wfm Nchan Nsamp or Analog 1D DBl Nchan 1samp.
I had a Beginners mistake. Thanks GerdW....
(2,267 Views)
