reading multiple voltages
I want to read voltage data from two channels as well as a counter, but I have my VI configured to read only one channel and counter. I am using the AI one scan VI to get the voltage data, do I need to use a differnt VI?
(2,873 Views)
Bertros,
As long as the channel is on the same device, you can just put the channel name in the next index of the channel array going into your AI one scan VI. Your data will be an array with 2 elements, in which you are already breaking out index 0 to get the first channel; get index 1 for the second channel, etc.
Incidentally, what are you using your boolean shift register for? I see you putting values in, but you don't use it anywhere, so you don't need it.
Mark
(2,873 Views)
