reading problem on a HP 6645a
I have a VI called "wait for RQS" which is not working, whereas all the other Vis concerning the 6645a work perfectly.  The aim of this VI is to read the tension and the current delivered by the 6645a. The error message is "VISA Wait on Event in Wait for RQS.VI" code: -1073807. I found no way to solve it. Could somebody please help me?
(2,713 Views)
nobody has an idea?
(2,701 Views)
Is this the HP6645 power supply? I use the 6642 which uses the same LabView driver and I could not find the VI you referenced. RQS I beleive refers to the GPIB request service if that helps at all.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,689 Views)
