reading special file formats
Ben, Yes there is only header. I like the phrase "patience was required" 🙂
[BADGE NAME]
Message 11 of 13
(966 Views)
Thanks for the references. Appreciated.
[BADGE NAME]
Message 12 of 13
(964 Views)
One hint that will let you know the file is too large for the read from spreadsheet function.
If you can read a small file OK but when you point at a large file you get an "invalid ....???? " (memory fails me) the read from spreadsheet functions are failing becuase the file size exceeds the I32 file size that the spreadsheet functions support.
Just don't get side-tracked thinking the path suddenly is invalid. To read more the I32 byte count the sub-VIs will ahve to be rewritten to support 64 bit offsets.
Just trying to help.
Ben
Message 13 of 13
(960 Views)
