reading with visa
Hello, I'm using serial.vi from NI Exampler Finder. I try to get results using COM1 for read and write, but I get error number 1073807339 (Timeout expiredbefore operation completed). What can I do? I'm using an example and I have no results!. Please, help me.
Luz
(2,940 Views)
Which example vi are you using excatly ?
What kind of device are you trying to communicate with ?
Can you tell after which phase the error shows up, only after a "read" or right after the "open port" ?
Are you sure about the settings ? (baud rate, termination char, ...)
Tryin' to help...
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,934 Views)
Sorry, the cable that I used was wrong, my .vi file it's ok.
Thanks.
Luz
(2,920 Views)
