real time 3D plot of spectrum
Hi
Would you please show me with a basic example how can I plot a 3D graph ( time-frequency- amplitude or time-frequency-power) in real time? I can use the modulation toolikit blocks to plot amplitide vs f or power vs f but I don't know how can I add time as the third axis . Considet the IQ sampling rate is 200k and the carrier frequency is 2.4 GHz
Many thanks
(4,110 Views)
Accepted by topic author tintin99
Not sure what kind of performance you are expecting (and you can achieve) but if you get a series of A(f) plots that you want, say, to represent as a waterfall type of 3D graph, the 3D waterfall graph example should be a good starting point (accessible through the detailed help).
You have two options in it: either pass the whole data set as three 2D arrays or two 1D arrays and one 2D array. Here is an illustration with the latter approach:
My dual core PC is completely overloaded by the 3D display task and rapidly fills up its memory...
HTH.
(4,101 Views)
Many thanks . The ramp function was my problem.
Just few questions
1- How can I take measurments every n seconds. Do I need to just change the input value of Wait function to n*1000 or it is better to yse a timed loop
2- Also how can I export the value of X,y,Z to excel
3- And finally I have the same problem for 3D display. Is there any solution for it?
(4,093 Views)
Just few questions
 Changing the wait function argument should do the trick. Timed loop are really meaningful only with realtime systems (FPGA, RT OS).
You could export to a tabulated ASCII file using File>> Write to Spreadsheet File VI.
You could NOT use a 3D display and limit yourself to displaying those curves on a Graph, for one. Or if you absolutely want to use this representation, only display the last 30 or whatever number is convenient for you (as illustrated on the attached example).
(4,082 Views)
