real time data acquisition using sim900d module (not arduino0
hi,
I am doing my final year project. I am sending data from a remote location using sim900d to the other module(sim900d) connected to my laptop. Now, I need to import the data acquired through sim900d connected to my laptop into Labview. But i do not know how. Kindly guide me
Message 1 of 8
(3,586 Views)
is the data remain stored in sim900d? what i understand so far is sim900d is accessed through AT commands . the interfaces it supports are spi, serial. so if you can directly connect your sim900 with laptop via serial port then i think it is possible tc ommunicate between sim900 and labview
Message 2 of 8
(3,578 Views)
yes..i have recently started using labview and don't know how to access the port or sim900d through labview.....will i have to write the AT commands in labview also...? i have watched many videos in which they use DAQ in labview but i don't understand how to install and use it..
Message 3 of 8
(3,557 Views)
can AT comands be send on serial port? have you send AT commands before using microcontroller or via PC. if you have sent it before using controller serial port then you sending from labview is easy. but first it need to be clarify that you have done this before using micorcontroller or PC via serial port
Message 4 of 8
(3,547 Views)
Accepted by topic author green157
i have searched it and find a link as follows whcih uses serial port to send AT commnads
http://www.codeproject.com/Tips/583315/Using-SerialPort-and-AT-Commands-for-Querying-Cell
so now sending AT commands from serial is easy. first consider the sending part. for this you need VISA serial config VI and VISA serial Write VI. you can serach these VI by right click i your new VI block diagram and press the search button on top left corner. there you type serial port and you will get a list of VISA serial VIs.
here is also a link from ni
Sending sms using LabVIEW
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Sending-sms-using-LabVIEW/m-p/2032036
Message 5 of 8
(3,537 Views)
i have checked the module by sending the AT commands via pc.....i successfully made a call and transmitted the message using hyper terminal
Message 6 of 8
(3,527 Views)
Then is your problem solved?
Message 7 of 8
(3,521 Views)
it turned out that i had sudent version of labview...now i have to download ni VISA
Message 8 of 8
(3,496 Views)
