real time logging
I would like to create a VI that starts timing at 2V input and stops timing at 5V as if I was using a stopwatch. Then when opening up the measurement file it has a column for time in seconds and voltage in second column.
(3,179 Views)
Suonds simple enough, post what you have done so far.
=== Engineer Ambiguously ===
(3,174 Views)
