real time multi XY graph
my idea is to create a multi XY graph with 3 plots
but, I can only use the same mathod for 2 plots, it works
but, can't work with 3 plot!
can someone help!
thanks
(5,728 Views)
I should also point out that the reason that I am doing this is that I want to plot the data as it goes!  So, the user can see the dots appear in real time
(5,724 Views)
Hi BooJay,
you can do it like this.
Mike
(5,723 Views)
Hi BooJay,
i read you post to late. Attached is a flexible version with realtime view.
Mike
(5,710 Views)
Thanks Mike!  Before I could finsih typing to answer your first post, we had a power outage for 2 seconds!  Hahaha!
ok now, I have check both of your solutions!  i will try it later!
but, the question that I really have is why my solution works with 2-plot, but not 3-plot!?
(5,706 Views)
Hi BooJay,
i don't know.
See this example in your LabVIEW folder for all possible XY Graph types.
(...LabVIEW X.Y\examples\general\graphs\gengraph.llb\XY Graph.vi)
Mike
(5,683 Views)
thanks again, Mike!
well, I did look into all the examples already!
but, I can't find a solution for it!
the problem with 3-plot, it tells that link a cluster with 4 elements to 2 elements are impossible
with the 2-plot, LabVIEW, it automatically becomes cluster with 3 elements for the XY graph!
weird!
(5,681 Views)
