real time on x axis
hi,
i am having a problem trying to get the real time on to the x axis of a graph. i have converted the number in to seconds but i still do not understand how to get the real time on the x axis from this point. i have looked at the Varible-Time Chart XY.VI but stil don`t
thank
mike
(2,694 Views)
You probably need to change the graph x-scale property to absolute time.  Right-click the graph, select properties, goto Format and Precision tab, select X-axis from pulldown and pick absolute time.  This is for LV ver7.1.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,656 Views)
BTW, there is also a tricky little box in the scales tab.  Only when the X-axis is selected in the pulldown you see a selection box called 'ignore waveform timestamps on x-axes'.  You must turn that off to see real time on the graph.
(2,653 Views)
