rearranging bits
I have the following array of binary bits
What I want to do is take each of the bits for each of the elements and arrange them as an element for example:
as shown below the 1st 8 bits for each of the elements are arranged on array 2 as an element of 8 bits:
0 ---->00000000
0
0
0
0
0
0
0
(3,824 Views)
Accepted by topic author RFeng
I would look at it this way.
Convert the numbers to a boolean array.  Do it in a loop to get a 2D array.
Transpose the boolean 2D Array.
Convert each row back to a number withing a loop.
Turns out it also needs to reverse the 1-D boolean arrays before and after the transpose.
I'm sure there are other ways to do this, and some may be more efficient.
But this works.
(3,797 Views)
I'd call on my old buddy Type Cast Man
(3,788 Views)
That worked! Thanks.
(3,778 Views)
This also worked.  Thanks.
(3,776 Views)
Of course real programmers really hate to have green bits, because they use 8x more memory. Here's an all blue solution that works just as well. 😄
(I am sure it can be simplified further;))
(3,758 Views)
Plenty of alternatives. Here's another version, same result (many repetitive operations can be precalculated):
Note that this old idea could eliminate the inner FOR loop, so please vote for it. 😄
(3,740 Views)
