rebooting PIX 8106 without screen
Hi
I have a PXI 8106 running Windows XP, but I don't have any screen (monitor) connected to it because the system is controlled remotley via TCP/IP
My problem is that if I reboot the system remotley (using Windows remote connection or VNC) the system hangs in the reboot sequence because it does not detect any monitor. Any idea on how to solve this without connecting an external monitor?
(2,477 Views)
Hi Garcas,
when you go to the bios you can disable the monitor, but be careful with this.
If you want to enable you have to go again to the bios, but of course you dont see anything anymore... Smiley Wink
Well, there is a Jumper to reset it again as well
Greetings, RMathews
Message Edited by RMathews on 04-02-2008 05:12 PM
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,448 Views)
