receive gmail
This has probably been asked before, but if it has I cannot find it.
I would like to receive email, from a Gmail account, it uses SSL.
I am running LabVIEW 13, if anyone has an example that would be a great help!!!!
Thank you!
Bob
Message 1 of 9
(8,042 Views)
http://lmgtfy.com/?q=receive+email+labview
http://forums.ni.com/t5/LabVIEW/reading-emails-from-gmail-by-labview/m-p/980940#M439357
http://alwan.over-blog.com/pages/How_to_receive_Email_from_Labview-7375818.html
Start with those and see how they work for you?  Or, at least show us what you've tried.  You'll see the google search I used was pretty much the exact subject you used for this thread.
Message 2 of 9
(8,024 Views)
Thank you very much for the information.  I have looked at these and I still don't understand.  If you or anyone has an example that would be great!
Again thank you!
-Bob
Message 3 of 9
(7,986 Views)
Thank you, but I guess I didn’t explain this enough, all I want to do, well for right now, is read emails from Gmail, in a way that I can parse the content. Gmail uses SSL, and with all the settings set to allow other programs to access it, I still can NOT do it.
Is there any way to do this within LabVIEW?
If anyone has an example that would help a lot!!!  I am using LabVIEW 13
Thank you very much!
Bob
Message 4 of 9
(7,952 Views)
You just got a reply with 3 links in it. The middle link seems to be exactly what you are looking for. What is it that these solutions are missing?
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 9
(7,947 Views)
Mike;
Yes, and I think it would be, but I cannot get it working.  I get this error:
Error 1386 occurred at Constructor Node in DOTNET POP3 Client.vi
Possible reason(s):
LabVIEW: The specified .NET class is not available in LabVIEW.
I must be doing something wrong, how do I register the 'Higuchi.Mail.dll" so that LabVIEW knows to use it.  I have never worked with .net stuff before.
Bob
Message 6 of 9
(7,934 Views)
Did you unzip the two files so they're eright next to each other on your pc?
Message 7 of 9
(7,925 Views)
Yes, what I ended up doing was moving the ".dll" to the main LabVIEW folder.  That fixed it.
I have it working now.
Thank you so very much!!!!!!!!!!!!
-Bob
Message 8 of 9
(7,896 Views)
I used the same dll to receive messages from my local server.
it is not working offline. even though the mail server is accessible offline.
it works fine in computer connected to internet.
is there is any requirement for internet????????
Thanking you.....
Message 9 of 9
(7,276 Views)
