record values and show them to a graph
in my application there is a loop where i get my values. there are eight different values (temperature, voltage,..) each loopcycle.
I want to show this eight values as eight graphs on one chart with the option to select one or more graphs of the chart.
(2,450 Views)
What do you mean by "select one or more..."? Do you want to select which ones to display and hide the others?
Simply use a few attribute nodes to interactively color the uninteresting traces transparent. See attached primitive demo (LabVIEW 7.0).
(2,450 Views)
Thanks for this example.
it's perfekt for my application.
(2,450 Views)
