record with mic met 4823 error
I write the attached vi, the purpose is to make six mic recording in parallel.
Looks like it can't run in parallel and sometimes met the error code 4823.
could someone give some suggestion on this?
(1,267 Views)
Add sub vi for the test.vi
The error always occurs in  Sound Input Read (DBL)_Reentrant.vi
(1,235 Views)
Hi, have you solved it?
(1,128 Views)
