recording multi input data from DAQ using labview
I am doing a project using Labview 8.2. Can you please tell me how to record multi input data from DAQ assisstant?
Looking Forward to recieiving from you...
Monireh Hassn
(3,542 Views)
Select multiple channels.
You are going to have to be more specific about your problem. When you start the DAQ Assistant, info on selecting multiple channels is displayed and once created, there are two 'Add' buttons prominently displayed.
(3,534 Views)
Thanks for replying me but I did these steps from the DAQ assisstant however I don't know how to record these different inputs into excel files?!
Looking forward to recieving from you,
M-H
(3,504 Views)
It depends on how you want to do it. If you want to create native Excel files, then you can use the Report Generation Toolkit or look through the forums for ActiveX Excel examples. There are thousands of posts on the subject.
If you just want to create a file that Excel can read, the easiest way for a beginner is to use the Write to Measurement File function.
(3,501 Views)
