recording real time/plotting channels
I am using a DAQCard-6024E and a CB-68LP terminal block. Using LabView 8.6, I would like to write my data to a file using real time. I would also like to plot each channel on a graph in the front panel. I posted a picture of my block diagram so far. What do I have to do to record in real time and plot each channel?
 thanks, Scott
(2,813 Views)
You've already got the ability to save the data as it is acquired and you are plotting it, though I don't know why you are using an XY Graph (a regular graph could also be used). Since it seems you are already doing what you asked about, I don't understand the reason for the posting.
(2,809 Views)
