recordset not dynamically adopt the changes
hello
i am using dbtools connectivity toolkit. i had a table in access. i made one vi in labview which add, delete , modify record in that table. also by using next & previous button i navigate through records. next & previous has no problem but when i insert new record in table , that get added in that table. but i cann't navigate that record using next & previous. but i stopp my vi & again run it it will show me all records. my curcor is dynamic but get properties show it as keyset why ? also recordset not change but my access table change why
please give me some solution
(3,325 Views)
Perhaps you need to requery to get the updated recordset?
Posting your VI will help someone be able to find the problem.
(3,298 Views)
i am sending my vi. i choose my recordset cursor as dynamic then why its get properties show as keyset. after requery how i gave new reference of recordset. please see my vi & give me suggestion
i create dsn to connect access database.
(3,290 Views)
hello
i am sending my vi. i choose my recordset cursor as dynamic then why its get properties show as keyset. after requery how i gave new reference of recordset. please see my vi & give me suggestion i create dsn to connect access database.
(3,279 Views)
