red square border prevents continuous vi execution
i see a red square border in my vi diagram and whenever i press the run continuously icon,
the vi executes and then stops at a particular node at this point i have to press the
pause/continue button or sometimes i have to press the step out button.
i havent specified any breakpoints and the vi show no errors during compilation.
i have tried many things like disabling debugging ,checking the vi for breakpoint etc..
but none of them seem to work ,the red square border still seems to be there.
can u specify some way to remove this . am i doing anything wrong ? please guide me ..."
i am using labview 6i
(3,629 Views)
The red square border is indeed a breakpoint. Just select the breakpoint tool and point to some blank space inside the diagram. If the cursor is an empty (not filled in) stop sign then there IS a breakpoint there. Just click and the red border should go away and the cursor change to a filled stop sign. Give it a try and see if there is a breakpoint there.
Rob
(3,629 Views)
thanks robert for the reply,
it worked.
(3,629 Views)
The same problem but I can't find the Breakpoints Tool.
any body can help me?
thank you
(3,326 Views)
It's done
I use:
On fronPanel Menu:
Edit»Remove Breakpoints from Hierarchy
sorry for that easy question
(3,322 Views)
