redlab not recogniced in MAX
Hello
I have a redlab 1208ls. My software is labview 2011. The drivers and lib is installed for labview with the redlab software.
But it is not realy working.
In the MAX the redlab is not found.
Also the programm"devices and interface" in max is not listed.
Could you please help me?
Best regards
Micha
(2,866 Views)
Hi Wassermann,
as the RedLab is no hardware made by NI it will not be recognized by MAX! MAX is used to configure NI hardware!
You have to install the LV driver and use it's VIs that came with the RedLab. That's it…
(2,859 Views)
Thank you. I try it.
(2,828 Views)
