reducing the size of a 1D array
i have a rather silly question...
but this small thing is being used in a big code and creating problems.....
I have a 1D array and by using the size function i am finding its size.
But when i delete some elements from the array, the size function still shows the original size.... and this spoils the functioning of the entire code....
So, I can only add elements and increase the size but can never delete elements and reduce the size.... how to go about it???? thanx.....
Message 1 of 9
(4,742 Views)
I suppose you are talking about 2-D array. I think in labVIEW a 2-D array will always be square. That means even if the number of elements in each row or column varies, the size will be decided according to the row and column with maximum number of elements. But  when a 1-D array is considered , if you delete an element the size also is reduced by one.
Even I am interested to know if there are any alternatives.:)
Nitzz
(Kudos are always Welcome, Mark as a solution if it is the One;))
Message 2 of 9
(4,736 Views)
i am talking bout 1D array only....
but after deleting the element.... the size is not decreasing..... r u sure its decreasing for u??
Message 3 of 9
(4,731 Views)
You should post the code you are using.
It certainly works correctly for me in v 8.5.
Ian
Message 4 of 9
(4,724 Views)
This is how i tried. May be sharing your code will help me understand better your problem.
Nitzz
Message 5 of 9
(4,723 Views)
u mean i have to use the delete from aray function each time???
cant i just delete the last element from the control panel.... and thus reduce the size by one??
Message 6 of 9
(4,709 Views)
it works fine..
Message 7 of 9
(4,699 Views)
right click the element..... data operations>> delete element.....
that seems to be the way to remove the element from the control panel..... 😛 😄
Message 8 of 9
(4,684 Views)
Thank you, Preetisar.  I spent almost an hour trying to find the answer to this very simple question.  It is such an elementary operation but in no way obvious.
Message 9 of 9
(4,626 Views)
