reed solomon VI gives error with higher values of n and k.
I am receiving the error message "Error -21872 occurred at mod_Validate RS code prms.vi"
If I use n = 15 and k = 11, it works fine. But if I use n = 64 and k = 32, it does not work and gives above mentioned error.
Can anyboody guideme how to fix it.
See attached VI for further details.
(2,534 Views)
This is a repeat post. The original post is located here, and has already been answered.
Matthew R.
Field Applications & Systems Engineer
(2,497 Views)
