reentan
hello
i've got a problem with my vi.
pictures from the vi's are in the attachement (pic.zip).
the problem is, that i have parallel loops(pic1.jpg) where this vi (pic.jpg) is used.
these loops give me a message if one of the elements in the cluster is true.
if the vi is reentrand it doesn't work and i got no messages.
if the vi isn't reentraned the messages are shown but not right.
markus
Message 1 of 8
(3,382 Views)
Hi
I can't really follow your program - is there a reason why there is the same loop several times?
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(3,377 Views)
excuse me, that was a mistake
the right picture is in the attachement.
in my programm there are four stations and each station can give an error. cause the stations haven't errors at the same time i had to take parallel loops.
markus
Message 3 of 8
(3,373 Views)
Could you post the subvi (as LV7.0)? I just can't see any reason why it shouldn't work and would like to test it on my system.
Using LV8.0
Message 4 of 8
(3,366 Views)
I attached the vi's
markus
Message 5 of 8
(3,359 Views)
The VI "Create_MessBox_TestEndText", unless there is something hidden in the FALSE case, should make no difference whether it is reentrant. There is no data storage that is expected to be persistent (and that's what changes based on reentrancy).
The other pic doesn't show enough for me to see any problem.
I don't exactly understand why you have separate loops - it looks like you're just polling several globals to look for a FINISHED flag, and popping up a dialog when found. You could do that in a single loop just as well.
Steve Bird
Culverson.com
LinkedIn
Message 6 of 8
(3,356 Views)
I attached the vi's
The file "_MotTempAverCheck.vi" does nothing and has nothing to do with the others.
If you want clearer help, you need to ask clearer questions, and provide more correct info.
Steve Bird
Culverson.com
LinkedIn
Message 7 of 8
(3,348 Views)
I just had a look at the vi - and I do not see anything that does not work as expected. The messages are also correct.
If your problem still exists, you should explain it better as CoastalMaineBird said.
Thomas
Using LV8.0
Message 8 of 8
(3,345 Views)
