reentering values in a table
I have an application in which i enter data in a table as user enters it.when user clicks on clear(a command button) i delete all the rows using DeleteTableRows in a loop,but the problem arises when again i try to enter data in same table,during the same run.  It shows me an error that index passed out of range (library error -55). how can i enter values in table??Smiley Indifferent
(2,976 Views)
Hi akath,
make sure that the index is correct. Can you upload your vi? I don´t really understand how you delete the table. Can you show it please?
Mike
(2,972 Views)
hi akath
                  your question is not staright forward. can u upload the vi. or give some image file..then only i can help u...
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
(2,967 Views)
I am enclosing a text file which contains the code for data entry and removal.
       thanks for ur replies and hoping that u have a solution for my problem.
(2,948 Views)
Hi akath,
which software do you use? Do we all speak of LabView? You know this is a LabView forumSmiley Very Happy
Message Edited by GerdW on 06-11-2008 11:58 AM
(2,939 Views)
hi gerdW,
the software iam using is CVI ,and as per my knowledge this is the place to discuss it.Smiley Wink
akath
(2,919 Views)
hi
     fine , you want to post question in CVI board , not here... post it here http://forums.ni.com/ni/board?board.id=180
Indrajit
(2,915 Views)
