reference on close button
hi @ all!
is there a way to get a reference on the close button on the upper right of the window title?
(4,079 Views)
i am not sure about reference but you can choose the way VI looks while generating the Executbales.
(4,073 Views)
Hi
Why do you need the reference?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,067 Views)
If you wish to use the [X] button to stop and close VI, take a look at the attached VI 🙂
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,064 Views)
@becktho: i need this because if i close my subvi with this button the mainvi doesn´t go on with running.
(4,056 Views)
If you click it in a sub-vi, it just closes the front-panel but does not stop execution of the subvi.
I have to possibilities you could try:
1. Disable the button and create a button to stop the vi
2. Use the event-structure to react on the button-click and stop the vi
Thomas
Using LV8.0
(4,052 Views)
