reference to task
Before, when creating a task, the Vi returned a Task ID, now Create task returns according to the help a reference to the new task, which make sense, however, when probing this "task out" we get the name of the task. This does not make sense.
Regards
(2,905 Views)
The name of the task that you see when probing "Task Out" is in fact the unique identifier for the task, which is effectively a string rather than a number. This is the name of the task is assigned in Measurement and Automation explorer. If you are creating a new channel within a VI, LabVIEW will generate the name of the task for you automatically. All task names are unique.
Hope this helps,
Regards
Message Edited by Tom O on 10-15-2007 05:44 AM
Tom
Applications Engineering, NI UK
(2,879 Views)
