reg:string control
Dear team
I am new  to labview. I am updating a string value using Boolean button (Ok & Stop button). Now I want to update string value it to string indicator using event structure. Here with attached the VI for your reference.
String value is not updating with string indicator. kindly check the code and revert me.
Regards
mohan
(4,488 Views)
Try this but try to learn Basic LabVIEW, I just provided a workaround in the same code.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,452 Views)
thanks. but can you send me the file in 2014 version
regards
mohan
(4,437 Views)
Check this
(4,429 Views)
thanks its working but how to avoid continuous updating in the string .I want to update the string only one time.
regards
mohan
(4,393 Views)
Thanks its working but how to avoid continuous updating in the string .I want to update the string only one time.
Regards
Mohan
(4,391 Views)
What a holy mess… 😄
See the attachment…
(4,378 Views)
