regarding queue and case structures
Thanks a lot for all your replies.Will try out the same concept as you said.
Message 11 of 14
(1,358 Views)
One simple change is to send Exit in a Stop:Value change instead of that network variable.
Also, why are the lights turned off, shouldn't the switch instantly to the next state?
Wouldn't it be easier to group the three lights into a cluster?
How often is the opposing lights out of sync, or can you simply copy west lights to east?
If North is green and i press north vehicle button, why does it turn red?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 14
(1,345 Views)
hi, When north sensor is pressed the sequence should be as per the second tabulation.You can refer the question paper attached.Also using a cluster would make it more simple as you said.I dont understand why you are asking me to use network variable.
Message 13 of 14
(1,308 Views)
I'm asking you _not_ to use it, as it was one (or similar) in the code, thus the idea of queing Exit.
/Y
Qestit Systems
Message 14 of 14
(1,299 Views)
