regatron power supply connection
Hi all,
i am trying to creat interface between a power supply and PC (with igor pro). is it possible to connect power supply directly to igor or i have to use a DAQ (already i have NI 6341).?
if it is necessary to have a NI DAQ in between, i should use a RS 232 cable for connecting power supply to NI DAQ and then using a usb cable for DAQ to PC, right?
i did some works and now i can see NIDAQ tools max in the data tools of igor pro and i can connect it to NIDAQ as a simulated device.
i wonder if you could help me by your great directions.
Best,
diana
(2,879 Views)
What does your question have to do with LabVIEW.
Do more research on RS232 as your comments make no sense and then post to an igor pro forum.
(2,858 Views)
