regex to check IP
https://regex101.com/ is a great site to test your regexes without having to make a million cases in LabVIEW. It also has an "explanation" panel to the side that gives you some tips on how to use it.
Message 11 of 21
(2,074 Views)
@pincpanter wrote:
@Yamaeda  ha scritto:
Your solution is great TiTou, but if you want to do it manually this is a solution:
This would make "10. 0. 0. 122" a valid IP, which is questionable (String To IP would refuse to convert).
Not sure if this is enough. It doesn't accept 0001, maybe it should. It does accept 001, not sure it should...
Message 12 of 21
(2,071 Views)
Do mean you make mistakes with reg.ex.? 😉
Message 13 of 21
(2,068 Views)
It probably depends on the context.
Just tried with Titou's code: 100.23.45.67 is translated back to the same address, but 0100.023.045.067  is translated back to 64.19.37.55 (as is 00100.0023.0045.0067). That means that any trailing 0 makes the function interpret the number as octal.
[Edit: as clearly stated in the help, of course: but I never noticed this]
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 14 of 21
(2,055 Views)
The farther this discussion goes, the more I like the original alternative:
@TiTou wrote:
-Kevin P
Message 15 of 21
(2,033 Views)
wiebe@CARYA wrote:
(([012]?[0-9][0-9])|([0-9]?[0-9]))\.(([012]?[0-9][0-9])|([0-9]?[0-9]))\.(([012]?[0-9][0-9])|([0-9]?[0-9]))\.(([012]?[0-9][0-9])|([0-9]?[0-9]))
Matches some none IP V4 numbers like 292.168.1.5
I use the PCRE
\A(?:(?:\d|\d\d|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d|\d\d|1\d\d|2[0-4]\d|25[0-5])\Z
Message 16 of 21
(2,020 Views)
I faintly remember entries in the forum where the IP to String function had side effects on the network stack, freezing VIs.
.NET should work fine (https://docs.microsoft.com/en-us/dotnet/api/system.net.ipaddress.parse?view=net-5.0)
Also, just for completenesses sake: The task to validate an IP address by regex is so common it even has its own website: http://ipregex.com/
Message 17 of 21
(2,011 Views)
Leading zeros are acceped sometimes. Leading zeros are not allowed, they are used for octal notation.
Message 18 of 21
(2,007 Views)
Hm..
If the reg.ex. is to support octal numbers, it's going to be even more complex.
I have used the string to IP trick before.
The string also accept "localhost", and IP to string will turn that into 127.0.0.1 or the PC's name (depending on the notation).
The string also accepts resolvable PC names, and even URLs. "www.google.com" resolves to 142.250.179.132, for instance.
If the goal is to validate a dot notation, it works. Except for octal inputs.
If the goal is to validate the string as a valid address, the IP to string output should be tested against 255.255.255.255 and 0.0.0.0.
Hard stuff...
Message 19 of 21
(1,956 Views)
TLDR;
Here's how I check for a valid IP address.
LOL, I just noticed someone already posted MY CODE!
I will take that as a compliment 😛
=== Engineer Ambiguously ===
Message 20 of 21
(1,935 Views)
